    Jun 2010
    Question wireing ceiling fan
    installing a ceiling fan. white-blue-black-ground wires
    ceiling box has two sets of wires coming in.
    (1)red-white-black-ground-inside black casing
    (2)white-black-ground-inside brown casing
    black wired together
    whites wired together
    grounds together
    red alone
    single wall switch controlled light and wall outlet.
    how do i connect the fan?
    the original light just had white-black-ground.
    thanks in advance for any help you can give me
    6,054
    Default Re: wireing ceiling fan
    Fan ground to ground, fan white to white.
    Fan black and blue to red if you want the switch to turn on fan and light.
    Fan black to red , fan blue to black if the switch controls fan and pull chain for light.
    Fan blue to red, fan black to black if switch controls light and pull chain controls fan.
    8,065
    You do the hokey-pokey and you turn yourself around ...
    Sorry, couldn't resist.
    Jun 2010
    Smile Re: wireing ceiling fan
    thanks for advice. fan,light working great.
    6,054
    Careful your age is starting to be revealed.
