    Jun 2010
    Default Weird plumbing question
    I live in a 1903 house with a mixture of galvanized and copper plumbing. It is a single story house. The majority of the plumbing is located in the basement. There is a kitchen sink, refrigerator supply, bathroom sink, shower, and washing machine. Everything seems to operate normally.
    Here is a procedure that makes something quite strange happen:
    1) I shut off the inlet COLD water supply to the hot water tank
    2) I open the HOT water side of the bathroom sink until the flow stops, and leave it turned on. It only takes a couple of seconds for the pressure to drop and the flow to stop.
    3) I open the COLD water in the kitchen sink.
    When I do this, the cold water coming from the kitchen sink is very low flow, but the bathroom sink starts flowing COLD water rapidly (I left the hot water valve turned on). How can this be?!
    Dec 2009
    40
    Default Re: Weird plumbing question
    sounds like the kitchen faucet is a single handle and the water is crossing over into the hot side.
    5,995
    Ditto to the above.
    Jun 2010
    The kitchen sink has two handles, but it has been causing us problems lately. The hot and cold water pressure in the kitchen sink is poor. I believe some O-rings are deteriorating and I thought the mechanism might be clogged because of that. But perhaps more is going on than I thought. I'll investigate the kitchen sink. Thanks!
