    Jun 2010
    Default Electrical outlets
    I have two outlets on the same circuit one works, one doesn't. The bad outlet worked just ten hours ago. Now nothing
    8,065
    Default Re: Electrical outlets
    Outlets can go bad, though more likely is the connections are bad either at the plug or the one upstream.
    6,053
    It is a common phenomenon if stab connections are used instead of the screw connections on receptacles.
