    Jun 2010
    Default Tape on outlet terminals
    I've seen advice on replacing of outlets where it was advised to wrap electrical tape around the outlet to cover the terminals. My question being:
    By wrapping electrical tape around the outlet, doesn't this Become a fire hazard by preventing the outlet from dissipating heat?
    The deep South
    459
    Default Re: Tape on outlet terminals
    If the outlet is getting that hot , you have bigger problems than a couple of wraps of tape .
    Shamokin, Pa.
    645
    Quote Originally Posted by Learner View Post
    Going on that assumption, then the plastic coating and Romex sheathing could become a problem as well.
    8,046
    Taping the terminals of an outlet is to keep you from touching them to the sides of a metal box and other equipment in the box. A secondary reasoning is that it keeps you from getting zapped when working on it, however you're NEVER supposed to be working on live wires. A couple wraps of tape are not going to cause it to generate heat
