    Jun 2010
    Default Painting Uneven Inside Angles
    The bedroom has plaster walls with uneven inside angles. The ceiling was painted white and the walls were painted a dark color. The unevenness of the inside angles are more pronounced after painting, how do I minimize the effect of the unevenness?
    1,301
    Default Re: Painting Uneven Inside Angles
    Some recommend painting the wall color up onto the ceiling by 1/8" so the eye never sees the cut-in line straight on. (unless standing under and looking up).
    S_M
