Results 1 to 8 of 8
    May 2010
    5
    Default Need to raise a toilet.
    Situation: Home is on slab construction, and toilet was floor-mounted by an idiot with minimal slope on sewage pipe.
    Would it work to replace the toilet flange with a deep bodied flange? I found one with a 4" depth to fit a 4" pipe on http://www.plumbingsupply.com/toiletflanges.html.
    Is any structure available to raise the toilet accordingly, or would I have to build it up with concrete?
    What is available if I need to raise it farther?
    Do you have any other suggestions? Hopefully, I won't have to re-do the entire sewer pipe. The water table here sometimes rises to only 16 inches below the surface.
    Any help would be appreciated,
    Milt
    South*East
    1,208
    Default Re: Need to raise a toilet.
    I don't see how raising the toilet is going to help a sewer line that doesn't have the proper pitch.
    John
    May 2010
    5
    It's borderline. I think it has enough but no extra.
    Jun 2010
    I think that toilet is place where we can leave our all tension and enjoy some moment of our life.
    May 2010
    5
    But do you have a helpful repair suggestion for this?
    163
    Unless you intend to break up the slab for renovation access to at least some of the underslab sewer line, raising the toilet will do litte, if anything, to improve the drain system performance.
    Your problem, as you describe it, is that the horizontal line has insufficient slope--raising the toilet will only increase the short vertical riser, and the real problem won't be helped.
    azcasxasxasxasxa
    May 2010
    7
    it's up to u ``just as you like `feel comfortable!!
    MI5 DVD 1-5
    CSI New York Seasons 1-6 dvd
