    Sep 2007
    Default silicone caulk on wood windows
    Hi. Does anyone know how to remove silicone caulk off of unpainted wood windows? I would like to stain my wood windows however the silicone caulk is unstainable and needs to be removed.
    Is there a chemical remover that I can use that will not damage the wood? Thank you
    Sep 2007
    Connecticut
    Default Re: silicone caulk on wood windows
    As far as I know there is not a chemical that will remove the silicone. I have had to sc**** it off using a utility knife and single edge razor blade, sand the area and fill any gouges or holes with a good wood filler that will accept the stain.
