    Dec 2008
    11
    Default Dirt on Oven Glass
    We just bought a house and the oven is a small wall oven. I was trying to clean it yesterday and there are some drippings on the glass window you look through.
    The drips aren't on the inside of the door...or the outside...it looks like something dripped down through the holes on the top of the oven door....and are now sandwiched between the black glass of the door...and the clear glass of the window.
    Is there anyway to clean it? The drips will drive me insane.
    Dec 2008
    Default Re: Dirt on Oven Glass
    I had the same problem. If you will unscrew the screws at the top (on my old GE) of the inside oven door, you can lift it off and get to the inside of the glass. Hope this helps you.
    Mary Ruthe Carter
    dkcarter@sbcglobal.net
    Dec 2008
    11
    Quote Originally Posted by MRCHOME View Post
    Mary Ruthe Carter
    Thank you!!!!! We will give that a try this weekend. It's 2 loonnggg drips....and will drive me insane if I can't get rid of it!
    Mary
    Apr 2009
    22
    I use Dawn Power Dissolver on my oven glass - it works very well.
