    Jul 2009
    14
    Default Cleaning Tar off of Wires
    Greetings All,
    I am in the process of replacing the wiring in my swamp cooler. Found tar on the wires leading from the box to the cooler. ( I recently had my roof redone)
    Is there a safe way to clean the wires before I reconnect them?
    Shamokin, Pa.
    645
    Default Re: Cleaning Tar off of Wires
    Give WD-40 a whirl. Quite the cleaning agent.
    Midwest
    179
    WD-40 for sure. Make sure there are mechanical connectors such as wire nuts under the electrical tape as you will have problems with them at some point in time. Just twisting the wires around themselves is not approved.
    "Lead by Example"
