    Dec 2008
    Default convert a push button switch to a pull switch
    My parents live in a security bldg where they must push a button the allow guest to enter the building. I would like to turn the push button to a pull with a cord to make it easier to get to. do you have any ideas. Would a pull light switch work?
    The deep South
    459
    Default Re: convert a push button switch to a pull switch
    I's probably a " momentary " switch . Meaning that the contacts are spring loaded and are only closed as long as you hold the button down . Any switch you use will need to meet that criteria .
    6,116
    How about making a button pusher?
Name:	button pusher.JPG
    1,131
    How about replacing the push button momentary switch with a simple/normal toggle switch (light switch)? Flip it up for the required amount of time and then just flip it down.
    Or.....replace the push button momentary with a spring-loaded momentary toggle switch. Pressure is then on the side of the finger instead of the end of the finger. Don't know if that really helps... but maybe.
