    Default Low water pressure
    We are experiencing low water pressure in our second floor bath/shower with a single handle lever control. This only happens when we turn from cold to hot water. What can be the cause of this??
    South*East
    1,259
    Default Re: Low water pressure
    What make is the valve? I'm betting it's Moen. If it is the cartridge needs to be replaced.
    John
    Smile Re: Low water pressure
    Thanks John you solved the issue for me. Correct solution to the problem
