Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 66
  1. #41
    980
    Default Re: My Oak Floors Keep Denting!
    Quote Originally Posted by ****hiller View Post
    That should be "before swine".
    You can easily Google your way to the verse.
    (Am grinnin' and duckin' about now. )
    alright smart guy. did you notice no quotation marks? therefore wasn't a direct quote. as I have stated before I'm not a master of google.
    dang smart a&^
  2. #42
    1,131
    dang smart a&^
    Hey.....what can I say?
    It's what I do best........or so I've been told.
  3. #43
    980
    hey lookie there you can even do it without the aid of google
  4. #44
    6,080
    I think ****ie has been bewytched. Besides would it depend on what translation you use?
  5. #45
    1,131
    PS- BRP would be willing to help you with that, I suspect...if you should get a hankerin' to expand your skills.
  6. #46
    731
    Quote Originally Posted by jwdyott View Post
    No, anyone knows the difference between laminate and solid wood floor. This is 3/4 inch thick tongue and groove oak flooring.
    The Janka hardnesstest measures the hardness of wood. It involves measuring the force required to embed a 0.444 inch steel ball into wood to half its diameter. This method was chosen so that the result would leave an indention 100 square millimeters in size. The American Janka scale is in pounds force.
    The Janka scale for wood hardness list red oak at 1290, white oak at 1360, and hard maple only a little higher at 1450. Hard maple is the primary wood used for bowling allies and I'm sure you didn't have bowling balls dropped on the floor and I doubt any of you guests weighed enough to excerpt that much pressure. It would take a person weighing 300+ lbs standing on a sq.inch heal on the steel ball to make the indentation used in Janka test. The pins used in the heels posted by BRP has a sizable flat head and not likely less than sq. inch.
    I've seen stiletto heels worn on Southern yellow Pine floors without indentations and SYP only has a Janka rating of 870.
    I'm more inclined to think that you finish may not have been completely cured. Curing time is going to depend on the type of finish, number of coats, thickness of coats, curing time between coats, and age of the finish.
    By the way are you sure that they are indentations and not a blemish, like fish-eyes, in the finish?
    What the heck does a Janka hardness test have to do with 3/4" oak flooring? Your diatribe is absolutely meaningless as are your "hardness" numbers. These aren't 2" thick planks DUH and there could even be a knot or a pin knot, as he said this wasn't the most expensive grade of oak floor.
    Pig Slop!
    Questioning the fact set presented by the orginal poster which he repeated several times isn't opinion or inquiry you were disputing what he presented. TWISTED you are Jack.
  7. #47
    980
    this may sound bad but if that was the only place to be schooled, I would rather go with out. I wouldn't trust the education level.
  8. #48
    1,131
    Now stop that. It takes all the fun outta my jab.
  9. #49
    980
    the fact that you can't piece it together kind of says it all
  10. #50
    1,131
    Doesn't sound bad to me........sounds pretty wise.
