    Dec 2008
    Default Baseboard Heat Expansion Joint Leaking
    I have expansion joints AKA (Full Expansion Coupling) in my basebaord heating system (Base Ray Cast Iron Baseboards) where the baseboard heaters transition to 3/4" copper in a closet between bedrooms. One of the expansion joints has a little bit of green crud near the fitting and it is leaking small amounts of water. Can I disassembly this fitting and repack it or replace a washer, or do I need to replace the expansion joint? SEE SAMPLE STOCK PHOTOS. If replacement required, are these readily available. I am in southern NJ area.
    Thanks, Stephen
Name:	Expansion Joint.jpg
ID:	1885   Click image for larger version.
Name:	Burnham Baseray Photo.jpg
    556
    Default Re: Baseboard Heat Expansion Joint Leaking
    Stephen:
    I would bring a copy of the photo of the valve around to your local heating parts stores---they should have a replacement, and possibly just the replacement washers.
    Consult the Yellow Pages under "Heating Equipment- Parts & Supplies".
    If you have trouble finding this item, the Slant/Fin site below also shows flex tubing that can also be used for this application.
    A third possibility would be to remove the offending coupling & solder a short length of copper tubing at right angles using ordinary 90 degree elbows.
    This would also allow the piping to flex slightly when heat expansion occurs.
    http://www.slantfin.com/documents/215.pdf
