    May 2010
    Default Humidity in double pane windows
    Can you DIY in removing the humidity in between double pane windows
    or do you need to hire a window spe******t to clean, reseal them?
    7,968
    Default Re: Humidity in double pane windows
    The only cure is replacement of the pane. This can be a DIY project if you're confident you can measure for the new glass properly, then remove the old and install the new. This is not an overly difficult project. Keep in mind that the pane will have to be ordered and will take up to a week, maybe more, to get.
    What type of window is it, i.e. aluminum, vinyl, wood, sash, casement, ??? And, is this a fixed panel or the operable one?
