Results 1 to 8 of 8
    May 2010
    Question rubber boot used to span space to connect
    Can a rubber boot be used to span the void between the pvc and the cast iron sewer drain>
    5,821
    Default Re: rubber boot used to span space to connect
    Yes it it can.
    7,146
    Rather than just saying yes, what it the technical name of the connector? It escapes me at the moment or I'd post it.
    South*East
    1,217
    I think he is talking about a Fernco coupling. This would be the preferred one to use.
    http://www.fernco.com/plumbing/shiel...el-shear-rings
    John
    7,146
    Yep, that's it!
    Thanks John.
    5,821
    [QUOTE=A. Spruce;201684]Rather than just saying yes, what it the technical name of the connector? It escapes me at the moment or I'd post it.[/QUOTE
    Senile old bat.
    7,146
    Senile old bat.
    You're calling me senile? You're the one who neglected to post "Fernco fitting" in the first place. To make it even worse, you didn't say whether the plain rubber Fernco would suffice or if the Fernco with the metal band was necessary.
    Sheesh ...
    Dec 2009
    40
    cp 44 no-hub coupling or comparable is what most inspectors want in Ca.
