    Aug 2009
    Massachusetts
    50
    Default Painting blueboard?
    I have gotten mixed opinions on painting blueboard. Some say it needs a skimcoat, some say just use a good primer. When I was buying sheetrock at Home Depot, the guy asked where I was going to use it, and I told him in the basement, and he said then "you need this" and brought me to the blueboard. I really had no intention of buying this, but the guy really recommended it. I have just one sheet hung at this point. I am not sure if I want to hang the rest now.
    1,823
    Default Re: Painting blueboard?
    Yes, blueboard can be painted in the same fashion as regular wallboard - drywall primer and finish coat(s).
    Aug 2009
    Ladson,SC
    192
    If it is water resistant sheetrock U S G recommended that it be skim coated.
    If it is The U S G imperior base board than if must have a veneer plaster applied.
