    Jul 2008
    40
    Default New vinyl over old
    I installed a no-wax floor 25 years ago in a small restroom with only a commode and is 3X6 in size. This floor is worn out but remains in tact and is solidly adhered to the floor. I am considering just installing a new no-wax floor over the old. This is a very small area with not more than 2 steps in either direction. Does anyone have any advice on if this will work and what needs to be done to prep the old floor. I plan to glue the new floor to the face of the old.
    8,046
    Default Re: New vinyl over old
    You can overlay any vinyl that is still solidly adhered to the floor, even if it's worn through or has chunks missing, as long as it's solidly affixed to the floor you'll be alright.
    You'll want to get some floor leveling compound, this is a dry product that you'll mix with water to about the consistency of pancake batter. This gets thinly skimmed over the surface to fill any voids or embossed pattern of the old floor. Before it fully cures (still slightly soft ) you'll sc**** your skimming knife over the floor to remove any ridges or lumps. If necessary, apply a second coat, or touch up deeper gouges if need be. Basically, any irregularities here will telegraph through the new vinyl. Once completely cured, give it another light scraping. Sweep up the big debris with a fox tail broom will do fine, better would be to vacuum with a shop vac, and you're ready to lay the new vinyl.
