    May 2010
    49
    Default put flooring on ceiling?
    i'm new, so bear with me & thanks in advance for any repiles.
    a friend of mine has some leftover tounge & groove hardwood flooring (3/4" thick X 31/2" wide X random lengths - 24" min.)leftover that he would like to put on a section of a vaulted ceiling in a room over his garage. these would be attached perpendicular to the collar ties, wich are at 16" spacing.the area is approx. 28" wide by approx. 27'-0" long.
    is it feasible to attach these directly to the collar ties, should we glue & screw plywood up first, or is this a bad idea overall. i'm concerned with sagging between the joists, as some pieces would only be attatched to one joist.
    any ideas or opinionms are appreciated.
    May 2010
    49
    Question Re: put flooring on ceiling?
    i realize there is a big spam overload, but doesn't anyone have any opinions on this idea?
    7,189
    Default Re: put flooring on ceiling?
    Shouldn't be a problem.
