Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Dec 2009
    40
    Default Re: What is the drain/flange supposed to look like?
    i would try a regular wax ring without the plastic horn because it looks like a 3" closet bend and the plastic horn might not be sitting properly.
  2. #12
    8,065
    Quote Originally Posted by Bay Area..Ca View Post
    Good call! Those few millimeters of plastic could make all the difference, and in this case the plastic neck would not be necessary, as the natural nipple on the base of the toilet should protrude into the floor flange.
  3. #13
    Dec 2008
    Midwest
    174
    I never use cant leak was rings. I dont like the way the plastic sits. never had a problem with regular was. Also the tile not bing completely under flange doesnt really make a differance. The flangs doesnt see any downward pressure. The bolts hook underit and pull up on flange.
