    May 2010
    Default Removing lead pipe from cast iron waste line
    I have lead elbow leading from base of toilet (no flange) to the cast iron waste line. I need to know how to safely remove the lead elbow, so I can rebuild the waste line with a flange to properly mount the toilet.
    Your help is urgently requested
    Thanks
    163
    Default Re: Removing lead pipe from cast iron waste line
    The lead is relatively soft, and you will be able to peel it out of the cast iron hub using a large screw driver, pry bar, etc. This will not create dust or fumes that you need to worry about.
    Keep the kids from handling it.
    Wear gloves.
