    Nov 2009
    18
    Default Patio door too tall
    I have a standard patio door going out to my deck. It measures the standard 80" tall. I need to replace it with a smaller door. I need to raise it about 6 inches on the bottom & I have no room at the top to make the opening larger. Do I have to order a custom door? Is there another standard size I might be able to find sold somewhere?
    Thanks.
    1,794
    Default Re: Patio door too tall
    Sclowry,
    Curiosity begs me to ask why you need to raise a door to a deck?
    In any event, if you have standard 8 foot ceilings in the room, you should have room to raise the patio door 6 inches after repositioning the header. A six foot opening would normally have 2x10 lumber doubled up with 1/2 inch spacing material as a header. Worse case scenario, a laminated header of lesser verticle dimension, but equal strength should give you clearance for the standard door.
