Results 11 to 20 of 23
  1. #11
    7,966
    Default Re: Hanging Shelves - Seems Simple But NOT
    Reminds me of the time I had to build some wooden shipping crates.
    This company was shipping some special equipement to a project in Egypt ... Mansurya if I recall.
    Anyway .... all I had available were Robertson screws .... meanwhile thinking ......driving the many screws into those crates .....hoping the guys over in Egypt had their red handled Robertson scewdrivers.
    Reminds me of back when I was learning automotive stuff. GM couldn't decide if they wanted to be metric or SAE, use flat head, phillips head, or torx head screws (still can't decide the metric thing, went with allen head screws! )
  2. #12
    LOL ... so true .
    You need all the above to change a headlight.
  3. #13
    7,966
    At the time of my automotive training, it was really demoralizing because you had to go out and spend a good chunk of change for a "basic" tool set that was both metric and SAE, with a few specialty things tossed in for good measure. This was nothing compared to the fully stocked tool room with all the REAL specialty tools and 30 years worth of factory manuals for the most of the big three models of the time, that the college I attended had. Again, at the time this was a transitionary period that all manufacturers were experimenting with various faster drive types (hex, square, torqs, allan, phillips, etc ), so the usual thing of the day was change, in spades, because you don't just have one size allan wrench, or torqs wrench, or any other style of wrench.
    A few years later I get into construction which made everything I'd purchased in the years before obsolete! Oh well, he who dies with the most toys wins, right? At the height of my career I had well over 6 figures worth of tools and equipment as a GC. Since then I've downsized a bit and am in the mid to upper 5 figures. If I were lucky, I could probably get about $500 for the whole lot at a garage sale! Now there's a lesson in depreciation and dip in the economy!
    If I look around a little, I'm sure I've got the perfect thing for mtngigi's shelf.
  4. #14
    731
    Quote Originally Posted by mtngigi View Post
    Okay - so hanging anything on my walls is always an exercise in futility and a major undertaking for me. A miracle is when I can hang anything so that it's strait, doesn't fall off the wall, etc. etc. I say all this so everyone knows what a non-handywoman I am.
    I want to hang this shelf - the kind that looks like molding with recessed holes in the back. I just don't get what I'm supposed to use so that it lies flush against the wall. I've drilled 2 holes, and used 2 screws that are drilled almost all the way into the wall (and therein seems to lie the problem). The shelf hangs, but it is just ever-so-slightly hangs away from the wall and not flush, for obvious reasons. What, pray tell, am I supposed to use for this kind of shelf?
    I got it at a thrift store so there were no instructions with it. I don't think it's a coincidence that the hole looks like a little screaming face, lol.
    p.s. I hope folks that answer don't get into a "I know more than you do" match, as that is what happened the last time I tried to get help here, and frankly, it's been a while since I've posted because of that bad experience. I just want some help - that's all.
    first off it is sad that your thread deteriorated both in the way you asked it would not, and that it has a lot of off topic banter. If you (like me) subscribed to it and every time you got an email it was another off topic post.
    apparently i was not as CLEAR as I should have been, although I thought the link to the type of screws diagram and description were clear enough, guess not since there was a series of just the type of posts you asked not be made after I posted.
    I did not mean the type of screws others have mentioned and pictured they tend not to work too well, the thin edges round over bend warp and cause problems when you try to hang, remove, rehang the shelf until you get it right, especially troublesome if after you settle on your mounting you go to remove it, patch other holes then remount, i've been there done that and its frustrating to say the least. I actually meant the types I mentioned and the washer trick had nothing to do with the type of screw head. since close proximity to the screw head is important to close the gap you need a screw that you can drive deeply to the wall also.
    the second thing is I noticed is that the screws that are holding your hanger plates seem to be rounded top screws. if that is the case you might want to swap them out for flat top screws that countersink into the plates that might gain you the flatness you need for a flatter against the wall install. Ace hardware sells loose screws and they're really helpful if you have one nearby you can bring the shelf with you and find the best replacement screws, guessing you'll need four total probably cost you a nickle a piece.
    if what I suggested doesn't work, you might be better off getting regular keyhole hanger plates they look like this:
    http://www.woodcraft.com/product.asp...&FamilyID=1928
    the other fail safe if you change to a regular keyhole hanger to use special hangman "bear claw Hanger" screws. these have that washer like post built in. this is what the bear claw hanger screws look like (click on link) http://www.hangmanstore.com/Hangman-...-Kit-p/khl.htm you can mouse over the picture to enlarge it to see how they are different.
    when I referred to using washers on the post I did not mean washer head screws, I meant to use two loose washers on each screw so that when you mount the shelf and get the screw head by itself or the screw head and one washer in the keyhole of the hanger plate and leave one larger flat washer between the backside of the plate and the wall before you engage it, the washer is between the wall side of the plate and the wall, as you push the floating shelf down to nest in the notch of the plate the washer helps tension against the wider open area of the plate, or the "mouth" as you called it, vary the washer spacing as to how many you catch in the mouth and how many are outside without having to remove the screw from the wall or keep driving our letting out the screws.
    works like the bear claw hangers, except in the situation with your seemingly proprietary hanger plate don't think the bear claw hanger screws would work quite right, but would with a more traditional keyhole hanger plate. I think that type of plate uses a proprietary hook sort of like a J hook but tapered not flat bar stock shaped like a triangle that locks it.
    instead of using floor protector pads you could use picture bumpers but they're basically the same thing unless you get rubber ones I usually don't use rubber but cork instead because the cork doesn't mark up the wall like rubber does and rubber can stain/mar the paint more often i use the felt protectors for chairs for actual pictures instead of official picture bumpers because they are even less likely to mark or scratch the paint then cork and they never stick to laytex paint even in the summer or under the heat of lighting.
    hope that helps and good luck with your floating shelf mounting project.
  5. #15
    6,015
    Quote Originally Posted by Blue RidgeParkway View Post
    I did not mean the type of screws others have mentioned and pictured they tend not to work too well, the thin edges round over bend warp and cause problems when you try to hang, remove, rehang the shelf until you get it right, .
    Blue, First suggesting a different screw type was not a reflection on your choices but a personal preference. Second if you had ever actually used the type of screws I pictured you would not have made the statement above. The entire head is hardened and you will not bend or round over the washer part hanging and remove the shelf hundreds of times.
    You also said "I meant to use two loose washers on each screw so that when you mount the shelf and get the screw head by itself or the screw head and one washer in the keyhole of the hanger plate and leave one larger flat washer between the backside of the plate and the wall before you engage it" this may be possible if there was one hanger near the edge but with two hangers trying to keep two sets of washer separated as you hang the shelf and have it adjusted to hold the hanger next to the wall is almost impossible.
  6. #16
    731
    I have used similar LOOKING screws as you have pictured they include such screws in assemble yourself cheap chipboard filled furniture, i don't like them. She needs to get the screw head closer to the wall and into it and have tension against the inside of the bracket to hold it tight to the wall. Those screws also don't have threads close to the screw head they are for joining two pieces of wood together one drawing to the other. Also it was the head shape not the driver that i was discussing earlier. I think the average homeowner wants to stick to the basics, slotted or phillips screw drivers, etc. and the type of mounting hardware they can access easily, cheaply and effectively, like molly bolts, expanding anchors and screws, wood screws, etc. and not have to buy more tools to make the hardware work. Another reason I didn't agree with that pictured above. however I wasn't referring to your commentary until you challenged that I had never had any experience with them - i was referring to the jkirk and havana and then the canuk a.spruce yacking that took place after i posted. but then you too got personal. guess it is like picking a scab you just can't resist.
    Jack, no it isn't impossible at all. let me explain what i'm talking about: case in point three apparently identical floating narrow plate rack type shelves from the store. not one of them had the mounting plates "mounted" the same on the backs. guess tolerances were/are sloppy overseas and quality and assurance non existant. wood was that hard but easily cracked hard asian tulip wood stuff almost like bamboo when not stained or painted, so wasn't about to start messing with mortising or chiseling out more to even it out or remove brackets to shim them out. you can bet that if they couldn't mortise out evenly for the two mounting brackets the deeper cuts for letting the screw head in weren't going to be smooth burr free or identically clean/unobstructed. wanted to put plates on display on them for a wall grouping they needed to be tight and secure then and always.
    add to that very old and not perfect walls.
    came up with the best middle ground for each shelf added washers for that distance minus the thickness of the mounting bracket plate and screwed the screws in a set distance from the wall used larger diameter washer but same size hole closest to the wall that matched the keyhole inside pocket behind the plate shy of the height of the top side of the shelf and the nesting spot when screw head is "keyholed" as a guide that when just barely able to see shelf was seated/nested in the hole, acts as a shim to wall. the rest let them fall and separate where they may as you push the shelf from a tilted to flat geting the head onto the larger "mouth" before you slide it down to catch on the shank or shaft of the screw in the nest or groove of the keyhole. this way if one bracket is mortised deeper than the other, or one is prouder off the shelf then the other or not level doesn't matter you're within a good tolerance. doesn't matter if left one is behind one or two washers it will fill in. if you have a noticible gap on one side versus the other just lift the shelf and do over. gap or no gap the mount is shimmed by the washers and tight.
    when happy with the mount slip bumpers on the back/underside, now shimed to wall at top of brackets and bottom, shelf secure. hope i explained that well enough for you to understand the washer trick.
    i learned from my helpful hardware man at Ace 70 yearold works mornings during the week as his son officially took over the buisness. its easier to understand with the stuff in your hand then it is to describe it, but it does work, just use solid washers not locking stars or split washers that will NOT work. washers are about a nickle each those cork disks you get 12 on a card for fifty cents.
    he also taught me the washer trick for hanging pictures that are strung with wire. you screw or nail two washers to the wall with a little gap then you nest the picture wire between the washers when you hang the picture, won't jump off the wall like on a nail head, and unlike a picture J hook won't make the picture lean out from the wall to collect dust on the back side of the stretcher frame. it works. two washers cheaper than heavy duty picture hanging hook and no nasty wire scratch marks near the hanging point on the wall, since you take the wire taught set it then carefully let the picture down then level it. bumper it up with cork or felt and you're done.
    Last edited by Blue RidgeParkway; 12-01-2008 at 02:14 AM. Reason: cleaned up link to image.
  7. #17
    Yikes.
    Let's go back to the beginning .... the OP purchased this at a thirft store with no instructions. It's likely the package had been opened at one time or another.
    Are these even the correct brackets .... who knows?
    If they are the correct brackets then it's likely the screws were included in the hardware packaging .... if so ...... all this discussion about screws is moot.
    Perhaps the bracket is upside down .... what fits into the hole in the center .... is there something that's missing ...... who knows?
    To me those pictures ... while always welcomed .... don't provide enough information.
  8. #18
    Jul 2008
    Colorado
    53
    Hmmm - another hijacked thread, guess no one read my ps, and maybe TOH isn't the best place to get answers. Though I might try one more time as I believe in 3 strikes before calling "out".
    To those of you who offered suggestions, thanks. I drilled the screws a bit more (almost flush to the wall), and the shelf feels much steadier now - though I don't think I'll try any more of these types of shelfs ... seems too complicated to get them to hang correctly and securely.
  9. #19
    6,015
    The screws I posted, I buy as pocket hole screws, the smooth shaft near the head means that there is no sharp threads to cut into brackets or wire plus they are self tapping even into 150 year old oak. That's why I like them. The entire screw is very hard and the head isn't much thicker than a pan head screw. I don't like those Chinese screws that come with particle board furniture either. Many driver sets you buy nowadays come with square drive bits so it has become quite common.
    I understand now what you mean by the washer set up you described, I wonder though how well it would work with a thicker brass hanger over a thin stamped hanger or wire. I would think thicker hangers would have a problem hanging up on the edge of the washer rather than seeking the slot between. Have you tried it on those types of hangers?
  10. #20
    980
    the screws jack showed are actually a very good screw and has been used commercially for many different trades and that head type is quite often spec. for many specific applications. the head type is refered to as a wafer head screw. they are used because they are a low profile screw (don't stick out much from the wall while providing large holding power.)
