    Nov 2008
    Cambridge, Massachusetts
    Default Adjust storm door closer
    No matter how much I back out the screw on our Pella full-view storm doors, they do not close all the way. The mid-view storm doors that were installed at the same time do close. Should I replace the closers on the full-view doors?
    MN
    455
    Default Re: Adjust storm door closer
    Try disconnecting the closer to see if it's a problem with the door binding somewhere.If it's not the door it might be the closer itself.
