    Feb 2009
    jupiter,florida
    20
    Default shower replacement/refitter?
    My walk in shower tiles are showing spider cracks.(are they leaking?)I'm going to have to replace my shower soon. Are there any opinions about the Bath Fitter or Rebath type of replacement? Instead of doing a complete rip out?Thanks
    Feb 2009
    jupiter,florida
    20
    Default Re: shower replacement/refitter?
    Any reply here??thanks, will the tile start leaking??trying to avoid a tile job?thanks
    If the tile is cracked, odds are that it's already been leaking and the swelling of the substrate has caused the cracks. IMHO, you're pretty limited as to what you can do because if it's wet already, they you want to open everything up to let it dry and replace the wet/damage. The only way to know if it's wet, and certainly, the only way to fix the tile is replacement.
    You could cover it up with an overlay, but then you haven't addressed possible moisture problems that will continue to degrade the wood and substrate for a very long time. Overlays are only for applications that you are certain are stable.
    Your least expensive replacement option (after removal of the old ) would be a full fiberglass insert. Next option would be a fiberglass pan with tile or a cultured surface. Most expensive would be a full tile or cultured unit.
    Feb 2009
    jupiter,florida
    20
    Thanks, the tiles that show the spider cracks are on the wall near the bottom?tiles are 20 yrs old?
    You will likely have moisture in the wall. No way to be certain without opening it up.
