Results 1 to 7 of 7
    May 2009
    10
    Default Is Sistering the Best Solution to This?
    Problem: Floor joist (under the kitchen) was cut/notched to make room for ductwork, as depicted in picture below.
    Given the constraints, is sistering the the best way to maximize the joist's support capacity?
    Default Re: Is Sistering the Best Solution to This?
    Good grief --- that's more than a notch --- a section of that joist has been pretty much removed.
    That's definately a bonehead thing to do----- at least they made decent cuts -----looks like HVAC guys are starting to be worse butchers than plumbers.
    The simplest option ( in a manner of speaking ) --- with construction adhesive sister another full length joist with 3 fasteners in a vertical row -- each vertical row spaced 12-16 inches.
    You'll have to unsolder the copper brace from the plumbing supplies and cut to fit to reinstall after.
    1,522
    hey canuk, no cheating youve been talking to engineers again havent you
    lol -- for the most part I don't have a problem with engineers --- now architects --- lordy that's a different story
    1,522
    engineers cool, architects some head scratching.. now interior designers - im going for a 40 oz of jack and reaching for the shotgun
    .... spits out mouthful of tea .... lol ---- interior designers ?!?!?!
    If only they could have one good idea and stick with it ...........
    7,588
    I'd settle for just having ONE good idea ...
