can i install polystyrene on interior walls up against sheathing which has stucco on outside?it would be glued and installed between studs then i want to add batt insulation and then 6 mil. poly which would be sealed with tuck tape and acousti-seal where i can't tape or would this trap moisture?i see some say use poly and others say not.thanks
