    May 2010
    Default Problem with light sensor
    Just installed DualBrite model 3009701/3209996. After setting time/on switch , it only turns on and off intermitingly
    7,080
    Default Re: Problem with light sensor
    Is the light also controlled by a switch? If not, install one and much of your problems will go away. I can't tell you why this works, but it does. I had a similar problem. The second problem i have seems to be with sensitivity, sometimes the motion sensor will work, other times not,
    Quote Originally Posted by Bunkerman View Post
    could you provide more info as to the issue?
