Thread: Planter box
    May 2010
    Wink Planter box
    OOOPS I just had built a planter box made from "treated" wood. Now I read that I shouldn't plant vegetables in it. Is that true?
    Also -- how much soil do I need for a box 10'x3'x1'??
    8,004
    Default Re: Planter box
    No, you should not use treated wood for vegetable planters, the chemicals will leach into the soil and be picked up by the plants.
    How much fill for a 10' x 3' x 1' bed? 10 x 3 x 1 = 30 cubic feet, just over one yard. (one yard = 27 cu.ft. )
    1,522
    very true about the pressure treated leaching into it.
    sprucey, do you think she could line it before filling with the soil though? so to stop any chemicals getting in
    8,004
    It might work for a little while. The liner would have to be non-permeable, yet durable enough to withstand direct sun and wet soil contact
    1,522
    when i started out in carpentry 8 years ago we did a deck with a box down on the ground which was turned into a pond, basically it was formed with rocks and then lined with a pvc type blanket product, this may work. now only if i could remember the exact product name
    8,004
    That is called pond liner in these parts, and it is still subject to UV degradation, that is why it is so diligently covered with rock and plantings. And in this case it is most important that the bottom have drain holes of be completely open so as not to become water logged and kill out the plants.
