    Nov 2008
    Default Problem with folding attic stairs
    Our folding attic stairs worked perfectly for a while, then developed a problem. When pulled down, it's as if the spring has too much tension on it, so the bottom section does not rest on the floor. The spring seems to be in the proper place, resting on the top of the spring carrier. They are not cut too short, and we can "get around" the problem by hanging a bucket of water on the stairs to weigh it down. But of course we'd like to solve the problem permanently. Any ideas about what may have happened?
    731
    Default Re: Problem with folding attic stairs
    Quote Originally Posted by lbartok View Post
    folding hinge sprung or bent or loose? truss uplift? wood dried out/shrunk? if you put a square of plywood on the floor or a small rubber backed rug at the landing spot do they reach? or maybe they're too long? maybe took on moisture and wood swelled/froze? ceiling sag? you sure they are framed correctly and still secure and not warped or out of square? was there ladder end feet (rubber, cork, etc.) originally that you put back on after you trimmed the ladder that fell off (hiding in the attic insulation)?
