Thread: pipe vibration
    Apr 2010
    Default pipe vibration
    After flushing the toilet and a several second delay, the pipes begin to vibrate. It begins as a low noise and get louder. This does not happen every time and lasts between 5-10 seconds. Running the sink or flushing again stops the vibrations. This began happening just a week ago. Any possible suggestions on the cause of the vibration?
    163
    Default Re: pipe vibration
    Probably a fluttering washer in the toilet's ball cock. Not hard to fix.
    Apr 2010
    Thank you, I'll check into that.
    May 2010
    I think its time to change the complete pipe that is responsible for supplying water in toilet flush. You can get this proper temporarily but this requires a complete replacement..
    avatar
    May 2010
    I have seen this before and it turned out to be the pressure reducing valve to the house.
