Thread: Expansion Tank
    Nov 2008
    Default Expansion Tank
    I replaced my old expansion tank on Friday and now it is starting to leak. What needs to be done now? FYI i replaced the last tank two years ago..
    Coventry, RI
    340
    Default Re: Expansion Tank
    Where is the expansion tank leaking from? If it is where it threads on did you use Teflon tape or some other pipe sealant? If not this is likely the cause. Hope this helps you out.
    Mike
    554
    I agree with sabo4545---is this an external leak or an internal leak---is the tank used for a boiler system or domestic hot water supply???
