    Nov 2008
    Default Gas boiler and tankless water heater
    A friend of mine has a gas boiler that creates their hot water. The water, however is 175 degrees. Is there any way to turn this down? They have a small child and do not want it to get scalded.
    566
    Default Re: Gas boiler and tankless water heater
    I assume you're talking about a hot water line that is connected to the boiler and supplies the kitchen and batroom taps with hot water (domestic hot water supply).
    There is usually a "tempering valve" that mixes some cold water with the water heated by the boiler---this is adjustable down to lukewarm, if needed.
    There's usually a valve with a knob somewhere in the cellar near the boiler---popular brand names (that may be stamped on the valve) are Watts, Sparco-Honeywell, Combraco and Generalaire.
    Some of the newer boilers have a tempering control somewhere on the boiler.
    If one doesn't exist, it should be installed, especially for the bath/shower/vanity taps.
