    Apr 2010
    Default Best Water Heater for my Needs
    I have a house that needs a replacement WAter heater. I also have radiant heated flooring which the water heater heats. Is there a particular water heater that is best for this kind of purpose or can I use any Water Heater? Is there a certain amount of gallons it should have things of that nature? The floor area of the home is 24x48.
    Default Re: Best Water Heater for my Needs
    Without any additional info, it is probable that you will do well to replace like for like, unless you are having trouble with the current setup.
