Results 1 to 7 of 7
    Default Formica Counter-top repair
    Tom Silva recently demonstrated on TV how to re-stick a Formica Counter-top using an iron. Either he didn't state or I missed which iron setting to use. I would appreciate knowing this before I try it.
    980
    Default Re: Formica Counter-top repair
    I didn't see the episode, but basically the heat reactivates the glue then you simply restick it. so I would say practice using the lower settings first because you can burn the face of the formica.
    731
    don't iron directly on the countertop use a buffer like a paper bag or a towel. you inserting heat activated glue? usually formica is installed with contact cement isn't it?
    980
    yes but it will reactivate with heat.
    731
    they finally posted an episode description today (11/25), 21 days after it first aired (yesterday the last one was first air date at end of october)! maybe now you can catch a repeat. here is a link to the description page: http://www.thisoldhouse.com/toh/tv/a...228407,00.html
    Thanks for the link. It really helped me out.
    I like having a Hidden Content .
    Oct 2008
    Southeast Virginia
    15
    I tried this on my 1950s green laminate counters and it does indeed work.
