    Apr 2010
    Default hanging pictures on plaster
    My 1915 American Foursquare has horsehair plaster walls. Any time we try to hang anything on the walls, the plaster crumbles away, leaving a hole and unable to support any weight. Any suggestions?
    1,387
    Default Re: hanging pictures on plaster
    Hi,Consider installing a trim board to then hang the pictures from it.
    1,794
    AMW,
    Are you trying to drive nails into plaster? I prefer to pre-drill holes and use screws when anchoring to plaster. Plaster is to brittle to drive nails into without often causing the surface to crater out. I use pan head screws which have a fixed diameter to the shaft, unlike wood screws, which have tapered shafts.
