    Apr 2010
    Default Wood support Beam and posts - shrinkage
    I have an 80 year old house in the midwest with a wood support beam (5.25" x 7.25") and wood posts (5.25" square, 6' tall). The posts are on concrete footings that rise about 8 inches from the floor. The house sags toward the center by about 2 inches. I want to finish my basement which would enclose the posts. My questions is: At what point does the wood stop shrinking? Is it safe to encolse the posts, or should I replace the wood posts with steel?
    Any helpful thoughts would be great.
    Thanks.
    Default Re: Wood support Beam and posts - shrinkage
    Is the sag noticed in the beam bowing or is the beam lower than it should be?
    If the beam is bowing, then it is undersized for the load it is carrying and should be replaced with a suitable sized member or reinforced. If the beam is lower than it should be, then that could be an indication that the piers under the posts are not large enough to support the load and they should be replaced with a suitable sized footing. Either way, it would probably not be a bad idea to get the input from an engineer who can do the load calculations to determine the proper sizing for the footings, posts, and beam.
    Structural issues aside, as long as there is no damage, rot, or pests in the posts, then there is no reason to replace them. You can encase them in a decorative column. If you want something unique, you can install load bearing, round, fiberglass columns. Depending on the load, the column itself may be enough, otherwise a steel post inside the column will do the trick.
    Apr 2010
    Thank you for your response.
    The beam and posts seem to be in good shape. I'll contact an engineer before I get started.
