Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
  1. #31
    Dec 2009
    Alpharetta, Ga
    55
    Default Re: How to Install switch to operate two lights.
    Maybe a diagram or pictures would help.
  2. #32
    Sep 2009
    37
    Ohmy
    Diagrams are located in previous posts.
  3. #33
    Sep 2009
    37
    New connections I think should do the trick?? I am using halo lights.
    At light 1
    A. (New cable black) connected at L1 to (Power black) and (switch white). (3 connections)
    B. White from (Light 1) and (light 2), new cable white (white wire from L4) to (power white). (4 connections)?
    c. black connected from light 2, and light 1.
    At light 4.
    A. (New Cable black) connect to (switch white), (black to smoke detector.) (3 connections)
    B. (Switch black) to (black Light 3) and (black light 4). (3 connections)
    c. connect white from light 3, and 4 and white from wire going to smoke detector.
  4. #34
    5,803
    Quote Originally Posted by RISurfer View Post
    Maybe I am missing something.
    Here are the connections I made.
    At light 1:
    a. switch white connected to power wire black (coming from circuit)new black wire going to light 4- 3 connections.
    b. Black connected from light 2, light 1, switch black ( 3connections).
    c. White connected from light 2, light 1, power white (coming from circuit, and the new white wire going to light 4. (4 connections).
    At light 4:
    a. switch white connected to new wire black (coming from light 1).black wire going out to smoke detector (3 connections)
    b. Black connected from light 3, light 4, switch black, (3 connections).
    c. white from light 3, light 4 white from new wire coming from light 1 and white going out to smoke detector. (4 connections).
    Did I mess up the wiring? Thanks.
    It's easy to look at the diagrams and reread the instruction.
  5. #35
    Sep 2009
    37
    Ha. For some reason I get confused with the concepts of electricity. It's like a foreign language.
    I figured it out. Everything works great.
    Thanks McDaniel for you patience and help! Saved me $700. Inspector comes tomorrow to check my work. Thanks again.
  6. #36
    Sep 2009
    37
    Electrical inspection passed. Thanks all.
  7. #37
    Congrats .--- you are now an official DIYer
  8. #38
    May 2010
    7
    I shake my head at the brilliance. The thought of switching an electrical conductor on or off is revolutionary.
    Do you think i can try this at home? Currently I just screw bulbs in and out when light is needed..... or not.
    Entourage dvd
    Lost dvd
