    Apr 2010
    Default planing painted boards
    We salvaged painted redwood. Planing it rapidly dulls the planner's blades. Anny suggestions?
    6,023
    Default Re: planing painted boards
    Either buy lots a planner blades or sand the boards first to remove the paint and dirt.
    8,002
    You could also use a paint stripper to remove the paint. Or, buy a surface sander.
    1,380
    Carbide planer blades are expensive, but if the redwood was free, you have some leeway.
    S_M
    Use stripper. DO NOT SAND THE PAINT -- don't even plane it unless you are positive that it's not lead paint. It's very dangerous to breath lead dust and you don't want it to settle on the ground and eventually enter the water table. Very hazardous stuff!!!
    1,890
    A machine that cuts away material to make a board thinner is a planer (with only one N). A book that you use to schedule your day is a planner (with two Ns). >:-(
