    Nov 2008
    Question under floor wurzbo heating
    Can wurzbo be run through the decking supports in the basement ceiling to warm the floors on the main floor? If so, what is the best way to go about this and can it be connected to a separate water heater in the basement?
    1,566
    Default Re: under floor wurzbo heating
    The way I've seen this done is the tubing is fastened to the underside of the decking and covered with a special piece of sheet metal that has a groove formed in it for the pipe. This acts as a reflector to direct the heat upward.
    Oh, and if you're searching for information ******, you'll have better luck if you spell it "wirsbo".
