    Jul 2008
    21
    Default Need a roof shaped cover over exterior stairs..
    ...maybe a strange request, but I will try to explain as simply as possible. Back of house, we have the "Dog Door". Dogs go out the door, take 2 steps to the left and go down 3 wide steps to the ground. Typically, during the winter the snow piles up on the stairs quicker than we can keep it shoveled and so it gets packed down and turns to ice. We "adults" never use this door during the winter except to go ou and try to shovel the stairs. The problem is confounded by the fact that we just "Trex'ed'the deck and the only problem with that is that it is now harder to shovel on Trex without scratching it. We don't use the deck in the winter and the overhang over the door keeps that part clear. I don't have any railing on either side of the stairs... What I was thinking was some sort of lightweight tent material put up in a roof shape fashion over the stairs. Being non rigid it would be hard for the snow to build up and with some sort of "flap" over each end, the snow would not build up very fast...Any thoughts or ideas for this crazy idea greatly appreciated. Thanks, Bill
    Nov 2008
    San Diego, CA
    7
    Default Re: Need a roof shaped cover over exterior stairs..
    To clarify; you’re looking to put up a cover at an elevation just above the dog door to keep snow from building up in front of the dog door hence the dogs can get in and out, no shoveling and no damage to new decking. Should work…
    2,009
    You might try a visit to an awning supplier. They are more common than you might think. Look at the strip centers around town. Awnings are everywhere.
