    Apr 2010
    Default Recommendations for very small (low-BTU) heating system?
    At our home in the San Francisco bay area, we're building a small outbuilding that will have an unheated garage as well as a room whose interior dimensions will be approximately 18'x9' with a cathedral ceiling whose peak is about 10'. (162 square feet.) It will be new construction (R13 insulation in the walls and floor, R30 in the roof; double-paned windows). The room will be primarily used as a gym, and one day possibly as a doghouse (for one dog). Given that use, and the fact that we'll probably only be in there a few times a week, humidity/ventilation is a bit of a concern (we really don't want it to become musty/damp/mildewy).
    As the room is so tiny, we don't want the solution we pick to take up any floor space in the room. We had thought that maybe the HVAC system could be mounted in the rafters/roof trusses of the garage and go through the wall into the gym.
    From the information at http://www.acdirect.com/systemsize.php, it looks like we need a heating system that can do approximately 5,700 BTU/hour.
    Energy efficiency is also a big concern--we have to get this approved by the "green building consultant" with our city.
    We did find an air to air heat exchanger that also includes a small heat pump (the Nilan VPL-15, listed at http://www.nilan.ca/indexen.htm and http://www.nilan.ca/hvac-book-pdf/ni...pl25-flyer.pdf). It looks ideal for our needs, but it's rather expensive, so we're hoping there might be something much more cost-effective.
    Any suggestions would be most appreciated.
    Thanks!
    163
    Default Re: Recommendations for very small (low-BTU) heating system?
    For both uses--gym and dog house--you will need good ventilation along with heating, and maybe cooling for the gym use.
    It's a common mistake to address ventilation from only one side, that is, either fresh air intake or exhaust, but, of course, both are needed.
    The heating and cooling needs could be met with a ductless mini-split unit, such as made by Mitsubishi and others. It is simply a heat pump that distributes the heating and cooling by means of a wall- or ceiling-mounted cassette that blows either warm or cool air. The other half of the system is the outdoor condenser.
    The ventilation could be accomplished by either pressurizing or de-pressurizing the space. De-pressurizing would mean that you use a fan to exhaust air from one end of the space, and have an opening with a motorized damper on the other end to allow fresh air in. The damper and the fan would be interlocked to operate together, and the switch could be operated manually or automatically. A pressuring system would have the fan on the intake side.
    This setup would cost less than the Nilan system, but would not be as efficient because the Nilan includes an air-to-air heat exchanger, if I understand their ad.
    6,053
    Might I suggest that for the size unit you are looking for you check on RV units.
