    Unhappy less than a 10 inch rough in
    I nee a toilet that will fit a 9inch rough in any suggestions?
    1,131
    Default Re: less than a 10 inch rough in
    You can buy an offset toilet flange which should resolve your problem. You might find these at a big-box, but I get mine via the local plumbing supply house.
    (If the install is in a slab you'll still have considerable work ahead of you removing a litttle concrete, installing and closing up again)
    http://www.plumbingsupply.com/toiletflanges.html
    http://www.hammerzone.com/archives/b...nge_offset.htm
