    Nov 2008
    Default Staining and Sealing New Redwood
    I have a new portch of heartwood redwood. Are staining and sealing two different things or can both be done with one material?
    Oct 2008
    Kansas City, Missouri
    126
    Default Re: Staining and Sealing New Redwood
    There are some products that do the same thing.
    Thompson's has a few that are tinted.
    http://www.thompsonswaterseal.com/pr....cfm?prod_id=4
    San Diego, CA
    367
    When I seal wood that's around our deck, I end up doing it about every year and I use a Spar varnish. It's specially formulated to resist UV rays. It's a little thicker than sealers, like Thompson's which goes on like water.
    I've used Thompson's and wasn't thrilled due to its viscosity. It'll still be a yearly task if you want to keep up with it.
    Good Luck.
