    Nov 2008
    Default Bathroom & Kitchen Designs
    More Out of Less
    In any type of small bathroom design, it's the plumbing fixtures that eat up the room. But there are ways to make these cumbersome necessities fade into the background.
    Toilet: A hung toilet has no tank attached so it slides right up against the wall.
    Sink: Most vanities come with small, useless counter spaces and cabinetry systems. Instead, eliminate the waste by installing a wall-hung sink which frees up floor space. Or a pedestal sink installed in an out of the way corner can deliver the elegance you want with the openness you need.
    Tub: Make this particular fixture do the work for two by installing a unit that works as both shower and tub. If you still want luxury, clawfoot tubs actually free up space around the walls and can be turned into a shower or Jacuzzi depending on the model.
    Shower: If you have a half bath, a quick bathroom design idea is to simply install a single-stall shower in a corner. And to make it invisible to the naked eye, invest in frameless doors or a clear shower curtain for a transparent appearance.
    check out www.imptile.com
    or www.decoprice26.com
    or www.deluxevanity.com
    MN
    455
    Default Re: Bathroom & Kitchen Designs
    Quote Originally Posted by Decoprice View Post
    More Out of Less
    Absolutely agree with that statement.
