Page 6 of 6 FirstFirst ... 456
Results 51 to 58 of 58
Thread: Outdoor wiring
  1. #51
    1,695
    Default Re: Outdoor wiring
    [QUOTE=kentvw;42700]
    I'd hate to bother my pet cat with this.
    QUOTE]
    I can't say I'd want to bother him either.
  2. #52
    5,836
    I was thinking of stopping by some time but.............
  3. #53
    Sep 2007
    177
    Just to close the loop...I decided to install a 12V system that uses a 300 watt transformer. I am using stranded THWN wire pulled through conduit...and I will probably solder the fixture connections because I hate those wire piercing thingess. I am not quite sure how to transition from the conduit to the fixture with the wires.. but maybe it is not that critical with LV? I would rather close it out with a box or something...but I am not sure how to attach the fixture to it.
    The fixture is made by Hadco model Pathlyte GAL3
    http://www.builderssquare.com/xp_835..._Pathlyte.aspx
    the PS is more than we need for 8 of these fixtures...but I may want to install something on the outdoor stairs later.
    Any comments?
  4. #54
    Denver, CO
    666
    The only comment I would have is to forget the THHN and use what Hadco recommends and cover the connections with "ground cover". THWN is not a direct burial wiring system.
    I'm way to biased to have ever gotten involved with this thread. I would be doing bollards on bolt down poured bases.
    If you follow directions from the manufacturer I'll give your system 5 to 10 years of life. Do you have a dog? Age reduced to a couple of years.
    Must say though, the fixtures are cool, simple fixtures...... I'd be really tempted to weld them up myself from steel square tube and let them rust.
  5. #55
    Sep 2007
    177
    Kent...
    Ah ha! So that is what you would do...poured bases. I was baffled as to what you were thinking.
    I was thinking of making the fixtures also. I ordered one....gonna check it out to see if I can replicate.
    So...is there any way I can use the THWM wire? I bought $55 worth of it and already pulled some through
  6. #56
    Denver, CO
    666
    http://www.vistapro.com/ProductAcc.aspx?ProdID=62
    Top left. There is a 1/2" hub on the top. You bury them and leave the single gang cover exposed and above grade. Your PVC conduit can turn-up and just dead end above grade.
    If you are interested I can probably make "arrangements" for wholesale pricing for you. (Why did I write that?)
  7. #57
    Sep 2007
    177
    Kent,
    Thanks for the link. Just humor me for a moment....what if I put a T ftting (see photo) in the ground and had the conduit come up out of that into the fixture? I know this is not your preferred approach....but it is 12V we are talking about. I figure just about anything is better then laying the cord directly in the ground and using those piercing devices to make the electrical connection
  8. #58
    Denver, CO
    666
    Those tee's are not rated for direct burial.
    Something like this maybe?.......... I have been on one very long, boring conference call.........
