Results 1 to 1 of 1
    Nov 2008
    Default No Water To Fixtures
    I reciently had a new water well dug and I installed a new deep well pump myself. When I went to check all the water fixtures in the house, I found that the water was not flowing to the rear of the house. The plumbing is of a PEX material.I checked for possible kinks in the PEX and found none. The water flows to the kitchen area, but not to the 2nd bath (BA2). I have included a drawing of the house with the cold water being shown in blue and hot water being shown in red. The system has a pressure switch that maintains the water pressure between 30 and 50psi. Could one or more of the PEX fittings be clogged? I did drain the system until the water ran clear, but obviously missed something..
Name:	No water.jpg
