    Sep 2008
    13
    Question Hot tub keeps tripping breaker
    I went out to use the hot tub the other day and the heater was not working. The internal breaker on the tub itself was tripped, so I reset it. The tub runs fine and heats the water as long as the jets are running. Within minutes of turning the jets off, the breaker will trip again. I had the jets running for almost 8 hours the other day trying to reheat the water after the initial trip, and it ran fine the whole time. Within 5 minutes of turning off the jets (the heater should have still been running) the breaker tripped. Turning the jets off in and of itself is not tripping the breaker, because I can immediately turn them back on once I turn them off. It has to sit a few minutes before the breaker will trip. And once it trips, it takes a few more minutes before it will let me reset it and the jets/heater will function again (before this time, resetting the breaker does nothing). I can't see any obvious reason for this to be happening, and nothing has changed with the tub. It's kept outdoors, we've lived in the house 4 years and the tub is even older. I need to keep it heating reliably so the pipes won't freeze in the winter, or I'll have to drain it for the season.
    Thanks for any help,
    Dave
    Coventry, RI
    340
    Default Re: Hot tub keeps tripping breaker
    This is just a guess but I would say the running water of the jets is keeping the heater from over heating maybe. When the jets are shut off it takes a few minutes for it to heat up to a point where it trips. Then it takes a while before it cools down enough for the breaker to be reset. This is just a guess as I don't know how a hot tubs plumbing is run. Hope it helps you out.
    Mike
