Thread: 220/110
    mid-south
    Post 220/110
    i got a shed prewired w ceiling lites and bench w pegboard. my question is there is a 220 outlet id like to temporarily step down to 110. is that possible? if so how w/o rewiring.
    5,775
    Default Re: 220/110
    It will depend on which type 220 receptacle it is and how it is wired.
    If it is a 4 prong receptacle you have 2 hots, a neutral and a ground. Wiring a plug with a black wire on either one of the hots and white on the neutral , and ground will give you 120 volts .
    It it is a 3 prong outlet and has 2 hots and ground, then no, because you should not use ground as a current carrying conductor.
    Shamokin, Pa.
    645
    Default Re: 220/110
    Quote Originally Posted by rudyruee View Post
    My advise is to call an electrician. Changing outlets, switches, etc. is one thing, but this is more involved.
    Default Re: 220/110
    The breaker for this circuit would also be a consideration --- depending on the rating may need to be changed to an appropriate size and type ( single pole from a bouble pole )
    6,940
    Default Re: 220/110
    Hey! How did you make the D backwards?!?!?!?
    Default Re: 220/110
    duh on me
