    13
    Default Multi-surface basement ceiling paint suggestions?
    I'm giving serious consideration to spraying my basement ceiling with paint -- joists, wires, ducts and all. I'll most likely be using an airless sprayer to do it.
    Is there a paint that will adhere to all these different surfaces?
    1,950
    Default Re: Multi-surface basement ceiling paint suggestions?
    SuperJ,
    An acrylic primer/undercoater such as Behr's No.75 will give sealing of the porous bare wood and great adhesion to the galvanized duct work. Finish coat with an acrylic interior paint. If using a stonger color, have the primer tinted toward the finish coat color.
