    Nov 2008
    Question "german-claw" tool
    I saw them using a tool to bring two beams together. It had a hook on each end that was pounded into each beam and then had a screw/ratchet to bring them tight together.
    What is this tool actually called and where can I get one. Not sure where to look.
    Oct 2007
    175
    Default Re: "german-claw" tool
    Closed-Captioning had it as "German Claw", but what it sounded like Norm Abram said way "German Klawde" -- either way a quick search using various spellings didn't turn anything up.
    And because a picture is worth a thousand words...
ID:	1766   Click image for larger version.
    Angry Re: "german-claw" tool
    You should be able to accomplish the same thing using a cable winch or come-along.
    Nov 2008
    I've been looking as well.
    http://www.timbertools.com/Products/...ome-along.html
    I've seen a similar clamp using a steel plate on either end instead of claws for a quite a bit cheaper. I can't remember where though.
    Hope this is what you were looking for.
    Nov 2008
    Smile Re: "german-claw" tool
    Found it.......Thanks guys!.....It is the ratchet beam tensioner found at timbertools.com.
    1,133
    Do you think it would work for getting crown molding tight to the corner blocks? ;-)
    S_M
